PXI
PXI-6361 Analog
I'm trying to send voice signal between two devices but one is not able to transmit. We checked the PXI 6361 connection for Continuity for the wiring everything seem to be good. Except when we check for continuity of the PXI 6361 between pin 22 and pin 21 there is a continuity in the circuit board. Did anyone run into this problem before? Thanks !!
(719 Views)
Pins 21 and 22 are AO0 and AO1, respectively. If they were sourcing 0V, checking continuity between them will show a connection as both are at the same potential.
Santhosh
Soliton Technologies
(692 Views)
Thank you for the answer. For the following on question, if a signal (Amp and frequency) going into AO 0 and another going into AO 1. I will still have the continuity?
(668 Views)
