PXI
PXI 6030e Voltage measurement
A couple simple questions.  First, what is the application that you are using this setup for?  Also, have you verified that the electrode is behaving as you expect it to?  Let me know!
Joe S.
Message 11 of 13
(947 Views)
Hi Joe,
My Interdigitated Electrodes (IDEs) are coated with a polymer and soak tested in saline at 85 C for a long period of time (about 1.5 months).  The purpose is to find the lifetime of the polymer.  I am using a wheatstone bridge to calculate the unknown resistance of my coated devices by measuring the voltage across the bridge.  I have read the resistance with an electrometer (high resistance meter), and also calculated the resistance with the results from a picoammeter.  I am expecting a resistance of about a Gigaohm or 10^11, 10^12.  So in short, the devices are doing exactly what I want them to do.  I am creating this test set up to receive a more accurate measurement.  As stated before,  when I place the IDEs in the bridge circuit, the voltage repeatedly oscillated from 3 values.  I know that this test set up works with a fixed resistor of known value.  I am trying to find out why it does not work with the device.
Thank you,
S.L.
Message 12 of 13
(936 Views)
Hi S.L.
It sounds like the device is functioning normally because the test using resistors of known value works as expected.  What resistor values are you using for each test?
Joe S.
Message 13 of 13
(921 Views)
