PXI
PXI-4462 - Microphone Set Up
I do have a power supply, what do you suggest I do?
LabVIEW 2016 - Windows 7
CLAD
Message 11 of 13
(1,244 Views)
Hi MeCoOp,
The easiest way to test your hardware is to connect a known signal to your 4462 analog input and to open up your 4462 DAQmx Test Panel in Measurement and Automation Explorer (MAX) in order to read in the signal. Make sure that you are staying within the recommended operating voltage for your card.
PXI-4462 Operating Voltage: -42.4..42.4 V
If you are not able to see changes in the test panel while changing the power supply voltage, then you can be confident that your card is in need of repair and will need to be sent back to National Instruments.
Jordan D
Applications Engineering
Message 12 of 13
(1,230 Views)
Re-installed everything, appears to be working fine now.  Thanks for your help.
CLAD
Message 13 of 13
(1,219 Views)
