PXI
PXI-4110 module
I am planning to use the PXI-4110 programmable power supply in my project. I have a requirement of a DC voltage of 40V can I obtain this by connecting the 20V and -20V channels in series ?
Secondly, I was looking for the output channel mating connector . The datasheet lists it as 1714964 of Phoenix Contacts make but I am not able to get the datasheet of this component as this part number is untraceable in Phoenix. I need this to make my custom cable for this module. Can somebody please help?
(3,609 Views)
Hello Shiladi,
Yes, you can obtain 40V by connecting both power supplies in series.
About the Phoenix Contacts part number I was able to find the Mini-Combicon backshell by searching for an alias on that part ("kgg-mc 1, 5/6" p/n 1714993) but for some reason they don't have a picture for that part or a description. My suggestion is to contact Phoenix Contacts directly since it's possible they have changed their part numbers. If I find the new part number for that part then I'll send it to you.
Tica T
(3,591 Views)
Thanks Tica. Appreciate your help.
(3,584 Views)
