PXI
PXI-1050 chassis timed out
System is no longer working after power failure.  Chassis timed out error in Automation explorer.  PC interface card has one green LED on.  All cards in the chassis have all LEDs on (PXI, HSDIO, DMM, & SCOPE).  Windows hardware manager shows "standard PCI to PCI bridge" but no "MXI-4 connection monitor".  Need assistance to determine which MXI interface card is bad, or if chassis itself is bad.  I have unplugged HSDIO, DMM & SCOPE cards and failure symptom is the same.
Attached is a zipped screen shot from automation explorer.
(3,177 Views)
Do you have any other MXI cards or perhaps an Embedded Controller to test if the chassis is bad? From your description however, it seems that one of the MXI interface might have gone bad. The only way you could test that, is if you had extra MXI card for either PC or PXI.
Best Regards,
Jignesh P
Best Regards,
Jignesh Patel
Principal RF Software Engineer
(3,147 Views)
