取消
显示结果
搜索替代
您的意思是:
PXI 1042 and 8187 controller setup
已解决!
转到解答
hi,
I am new to PXI controller and chassis. I have PXI 1042 chassis , PXI 8187 controller and daq cards on its slots. can anyone please help to configure from scratch and its lan connection (crossed or straight cable). which latest LabVIEW rt is supported by this controller.
windows 10 64 bit is installed on host pc.
and can i run simulink models in real time mode in this contoller.
thanks
0 项奖励
1 条消息(共 4 条)
3,876 次查看
解答
已被主题作者 DMic 接受
You can use LabVIEW Real Time module on this controller. The latest version is 2016.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YILGCA4&l=en-US
https://www.ni.com/en/support/downloads/software-products/download.labview-real-time-module.html
In regards of the simulink models here is a KB explaining about it:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHwKCAW&l=en-US
2 条消息(共 4 条)
3,836 次查看
thank you for reply but i have some more fundamental questions.
1. chassis 1042 with (pxi controller 8187 and pxi card ) is not detected in host pc
i am trying lan cable with cross connections and straight connections . but both cases i cannot see any indication of connection.
2. host pc has LV14, MAX 14,
3. i tried from MAX -> devices and interfaces-> identify as --> 8187 (identified but not .... pxisys.ini etc)
4. is there any way to check connection of host pc with controller.
0 项奖励
3 条消息(共 4 条)
3,827 次查看
Hello Dmic,
I really recommend that you post these specific questions in a new forum, because I have answered some of your questions related to RT, however there are people more experienced with PXI chassis itself. If you create a new forum this one will go to the proper customers/engineers more familiar with PXI chassis. They can help you better.
0 项奖励
4 条消息(共 4 条)
3,819 次查看
