12-13-2007 01:12 PM
12-13-2007 02:39 PM
12-14-2007 10:46 AM
Hi jmcbee,
It looks like you might have found a solution to your problem. However, when I tried to look at the link, it doesn't work. Would you mind relinking the document for others in the future? Thanks!
Also, I'm not sure if this is what you found, but one important thing to remember with connectors on a DAQ card is to associate the correct terminal block with each connector. This can be done in MAX by going to your device and selecting properties. Then in the accessory tab, choose the correct terminal block that is connected for both connector0 and connector1. Hopefully this information was helpful!
12-14-2007 10:49 AM
