PXI
NI2527 Card error issue
I would like to know if someone can say if this error is caused by hardware or a driver issue. I have a tester that gives this error a lot and would not want to change hardware if this can be fixed with driver update. The tester is also located in a remote location with a slow connection so it will be hard to get the driver update.
Specs
Win 10
Drivers Aug 14
PXI-1033 Rack
Teststand 2013
Error code: -1074108569, Error message: niSwitch Initialize With Topology.viNI Platform Services: A hardware failure has occurred. The operation could not be completed as specified. Device: NI2527 Status Code: -50152
(2,664 Views)
Hi Watre.
I've seen similar issues before being related to unexpected shutdowns/ sleep cycles.
In this knowledge article, it's explained why.
I also found this forum post, where another user with a similar setup had the same issue. which was solved with a restart of the system.
(2,557 Views)
