PXI
My XP machine doesn't recognize my PCIe-8371
I just installed a PCIe-8371 into my XP machine my box doesn't recognize/acknowledge the card after rebooting, restarting, flipping off the monitor and cussing up a storm. Any suggestions?
(3,769 Views)
So, just to make sure you are installing everything in the correct order, here are the steps to follow for this installation:
1.  Turn off everything
2.  Install PXIe-8370 card in SLOT 1 (controller slot) of the PXI-chassis.
3.  Install PCIe-8371 card in the computer
4.  Turn on PXI-1062Q
5.  Turn on PC
6.  Turn monitor back on, stop cussing
Also make sure you have PXI Platform Services, installed on your machine.
Scott
(3,754 Views)
Also, if you haven't connected the chassis yet, you probably won't see anything even if the card is recognized.  The PCIe card will show up in device manager as PCI bridges, but they're considered system devices and you won't be prompted to install them.  They won't show up in MAX at all.
If you want to see them, open device manager, view devices by connection, and start expanding a few things.  In XP it goes something like this: "ACPI Multiprocessor PC" -> "Microsoft ACPI-Compliant System" -> "PCI bus" -> "xx Root Port" or maybe a generic bridge -> "PCI Standard PCI-to-PCI bridge" -> "PCI Standard PCI-to-PCI bridge".  The last 2 bridges are the NI PCIe-8371.
If you have the chassis attached there should be more stuff below that as well.  The other thing to check is the DIP switches on the card.  They should all be off.
- Robert
(3,752 Views)
