05-22-2014 08:52 AM
I jsut inherited a 1065 chassis with two 6363 and two 4351. I am trying to use one of the 4351 for TC measurements but, when I try to configure one of the 4351 in MAX for a new temperature task it brings up the 6363 and not the 4351. I must be missing somthing.
Please advise
Solved! Go to Solution.
05-23-2014 04:37 PM
Teslac,
My first thought is that the names in MAX may be misleading. Double check that the names correspond the devices they describe. If that checks out I would power the system down, move the cards around and determine if this happens again.
After that start looking into clearing the MAX configuration. Be aware: THIS WILL REMOVE CUSTOM SCALES, DEVICE CONFIGURATION etc!!
http://digital.ni.com/public.nsf/allkb/2C7480E856987FFF862573AE005AB0D9
05-27-2014 08:25 AM
Thanks, I will give that a try by moving the cards.
05-27-2014 08:46 AM
You can not create DAQmx tasks, channels or scales in MAX for the 4351. It is not supported by NI-DAQmx.
http://digital.ni.com/public.nsf/allkb/BE27E48645E2DF1386256FBC007157AC
You will need to use the Traditional NI-DAQ Virtual Channels with the 4351.
