08-01-2008 04:51 AM
08-01-2008 11:22 AM
ITA,
The configuration you've shown will work with MXI-4 (PXI-8331 or PXI-8336). However, it would be better to place the top MXI card in the first segment (slots 2-6) to get better bandwidth to the second chassis.
You should also consider how much bandwidth the system will need. With a large number of cards the PCI bus gets less efficient.
Another option for the second chassis is to use MXI Express (NI ExpressCard-8360 and NI PXI-8360) from the ExpressCard slot on the 8106. This will give more bandwidth to the second chassis without taking away from the first.
Best of luck.
- Robert
08-04-2008 12:38 AM
Hi Robert!
Thanks for the inputs.
