PXI
Loosing TCP data between Labview and CVI
I am sending 30k or so packets every 100 milliseconds or so from a Labview RT PXI system to a CVI program so I am probably pumping data in faster than it comes out. I get a disconnect event in my CVI TCP handler. I have used the example programs on both sides to put it together. I have the TCP Write configured with unlimite timeout. I get a portion of the text message "00,00000000,00,DATA" where the first to bytes are a command number, the second set of 8 is the packet length, the following two are the error code, and then if followed by a long string of ascii data. I seem to lockup when I have sent about a half meg of data. On the CVI side, I get the packet length and request that much. When it returns, I subtract off how much I have read and retry the read until the entire packet has been read. Any idea of how to get around this or what the problem may be?
TZ
(3,194 Views)
Hi TZ
I would highly recommend posting this in either a LabVIEW discussion forum or a LabWinwdows/CVI discussion forum.
Also, when you do post on those dfs, make sure to include the error numbers.
Claire Reid
(3,168 Views)
