PXI
Labview & Teststand upgrade issues
We have set of sequences and vis developed to run autmoted tests. Originally these were created in LV 7.1 and TS 3.5.
Last friday I upgraded the versions to LV 8.6 and TS 4.1.1. Most of the functionality works as before.
There is one llb where we run set of teststand sequence from labview for our tests. This vi throws an error as in attached file.
To simulate the issue, open the llb and select either "Sequence Runner - Select Sequence Files" or
"Sequence Runner - Select Sequence Folder", run the vi, select the file or folder where seq file is present,
press "RUN" button on this window which open another TS Operator Interface, thats when this error is generated.
Let me know if any files missing or question not clear.
Note: I tried TS 4.1.1 with LV 8.2 and this file seems to run as before.
Message 1 of 1
(3,095 Views)
