Rob,
The PAGE_FAULT_IN_NONPAGED_AREA is one of those wonderfully vague errors that is tough to troubleshoot, and even tougher when it happens only intermittently. Usually this error is a result of either bad sectors on the hard drive or bad addresses in your RAM, but it can also be caused by a variety of hardware problems. I do have a few questions that might help:
1) Are you using an embedded PXI controller or a MXI cable connected to a desktop computer?
2) Have you changed the hard drive or RAM in your computer/controller recently?
3) Have you added any modules to your PXI chassis?
A few things to try troubleshooting-wise, although they would be much more informative if we could reliably recreate the problem:
1) Try removing one or more of the modules from the PXI chassis and see if one of the cards is causing the problem.
2) Run a hard drive scan from Windows and see if it detects any problems with your hard drive.
3) Run a memory scanning utility, such as MemTest86, and see if there are any problems with your RAM.
Good luck, and let me know if you find out anything else!
Chad B. »
National Instruments » ni.com
