PXI
I'm looking for a possiblitiy to read out 'Mahr millimar' sensors with a PXI card.
I have some millimar sensors and I would like to work with the data directly on my computer. For that I would like to use PXI and a appropriat card.
Do you see a good solution with NI components? Other companies are supplying cards for that already.
(4,522 Views)
You can read all sensors with our cards but you must be with your signal in our specifications of each card you use e.g. 0 to 10 mV or 0 to 20 mA. So often you need an amplifier or an transducer to form your signal in voltage or ampere with right range.
What signal and unit do you get from your sensor ? Do you have a datasheet ?
Best Regards
(4,513 Views)
I'm looking also for 'Mahr millimar' driver for my LabView Program
(4,348 Views)
We have additionally Signal Conditioning and special Voltage Ranges from +/- 80 mV to +/-10 V with 24 bit resolution -> 9.5 nanoVoltage Resolution possible.
So we can use almost all sensors with Labview. So please describe your specially specification for what card you need ?
For Labview drivers you can use dll´s with C programming with external function node when not finding Labview Vi´s.
Best Regards
(4,321 Views)
