PXI
How to create n number of pattern files automatically using and digital pattern editor and Ni 6570
Hi all, I need to create many pattern files (.digipat) to burst them into a chip. but it takes so much time to create too many pattern files. is there any alternate method for creating the pattern file automatically? I am using LabVIEW for automation. The instruments used are Ni 6570
Message 1 of 8
(2,642 Views)
Could you please elaborate on your application and why you would need a lot of pattern files?
Santhosh
Soliton Technologies
Message 2 of 8
(2,612 Views)
From DM:
As I mentioned in the post. I am just sending random patterns to the chip and checking as changes have happened in the chip this is my application. so I need to create patterns for forcing that into the chip
I would highly recommend continuing this discussion in the thread so that others are also aware of the discussions instead of just me. What kind of random patterns? is it really random like the PRBS sequence? are you doing a scan test or register read write or memory test? what exactly do these patterns contain?
I am trying to suggest the appropriate choice instead of having to generate a lot of patterns that you think might be the solution to your problem. If you still insist on going your way of the solution, you can generate digitpatsrc files (regular txt) and compile them.
digitpatsrc file format - https://www.ni.com/docs/en-US/bundle/ni-digital-pattern/page/digipat/text-pattern-file-syntax.html
how to compile them into digipat - https://www.ni.com/docs/en-US/bundle/digital-pattern-editor/page/compiling-patterns.html
You can generate these digitpatsrc txt files using your own custom program in any language.
Santhosh
Message 3 of 8
(2,588 Views)
Hi santo_13
I just want to create PRBS sequence that's it. not doing any read or write operations just want to generate some random patterns and burst those into the DUT.
Message 4 of 8
(2,577 Views)
There may be a better way based on your PRBS sequence length etc., but a faster solution is to create the digitpatsrc files using custom script and compile them, this way you can generate infinite patterns (limited by 657x specs of course).
Santhosh
Message 5 of 8
(2,554 Views)
Dear santo,Are there any relevant examples of how to create a standard digitpatsrc file
Message 6 of 8
(2,118 Views)
Hi JackLinZe,
You can refer to the below link that might help you to create a digipatsrc.
https://www.ni.com/docs/en-US/bundle/digital-pattern-editor/page/text-pattern-file-syntax.html
Message 7 of 8
(1,754 Views)
Links seem to have stopped working. Please fix them. (I pasted them here)
"digitpatsrc file format - https://www.ni.com/docs/en-US/bundle/ni-digital-pattern/page/digipat/text-pattern-file-syntax.html
how to compile them into digipat - https://www.ni.com/docs/en-US/bundle/digital-pattern-editor/page/compiling-patterns.html"
Message 8 of 8
(1,387 Views)
