PXI
How can I do frequency hopping using RFSA and RFSG
I am a newbie in Labview, and I am currently trying to implement frequency hopping in Labview. I combine OFDM ( i got the example from here https://decibel.ni.com/content/docs/DOC-34781 ) with Bluetooth frequency hopping example that I found in the forum https://decibel.ni.com/content/docs/DOC-20152  , but I guess there is some properties that is not supported in this VI. I use trigger to synchronize between RFSG and RFSA, but it seems like it doesn't work. I am using PXI 5646R and NI Labview 2015. Herewith I attach the error snippet and the VI, any example or explanation would be really helpful for me.
regards,
Renita
(3,825 Views)
Hi Renita,
Have you tried using the example as is? I see that you modified the block diagram to piece together portions of the community example, but I'm curious if you were able to run your the community example as it came?
Thanks!
Kevin S
(3,792 Views)
