PXI
Error -201003 on NI PXI 6509
I have a RT Application, which runs at the startup of my PXI. I am trying to create a new digital output task on NI PXI 6509. Some times it gives error -201003 while creating the task. The follwing is the error code description.
"Error -201003 occurred at an unidentified location
Possible reason(s):
Device cannot be accessed. Possible causes:
Device is no longer present in the system.
Device is not powered.
Device is powered, but was temporarily without power.
Device is damaged.
Ensure the device is properly connected and powered. Turn the computer off and on again. If you suspect that the device is damaged, contact National Instruments at ni.com/support."
I opened NI MAX and verified the card using the test panels, it is working fine. Does any one have simillar experience? Can any one help me with this?
Nanda
Message 1 of 1
(4,716 Views)
