PXI
Dynamic generation delay problem using PXI6552 trigger Line 0
I notice a problem of delay while dynamic generation with PXI6552 cards. I am using two PXI6552 cards, while one card is only sending a trigger on trigger Line 0 (RTSI 0) while the other card is waiting for the trigger and then starts a dynamic generation and acquisition sessions simultaneously.
I notice a delay of ~53 samples of the generation session. Thus the acquisition session samples ~53 samples BEFORE the generation starts.
I attached the sample program that I notice the problem.
I also noticed that this delay problem occurs always when I export the trigger (niHSDIO Export Signal.vi) and use 'Start Trigger' as signal. If I use 'Data Active Event' with another trigger type e.g. PFI0 (since I noticed it doesn't work with the PXI trigger Lines) then there is no delay.
How can I overcome this delay problem?
Kind regards,
Luc Cole
Message 1 of 1
(2,885 Views)
