PXI
Connecting BNC-2121 or 2120 to various cards
I have a PXI-6251 DAQ and a PXI-7854R FPGA. I also have breakout boxes BNC-2120 and BNC-2121. Which of these combinations can I connect? And what cable do I use to connect them?
I know that I can use a BNC-2120 and PXI-6251 together, I've been using that combination for a few years. But I can't seem to find the right place on ni.com that will tell me which pairs will work together, and what cable I need to make the connection. Thanks for your help!
(2,404 Views)
Please take a look at these documents as they explain what cards are compatible with the BNC blocks and explain which cables are necessary!
BNC-2120 Installation Guide
https://www.ni.com/docs/en-US/bundle/bnc-2120-getting-started/resource/372123d.pdf
BNC-2121 Connector Accessory for 660X Devices
https://www.ni.com/docs/en-US/bundle/bnc-2121-seri/resource/322640c.pdf
Main Page : DAQ Multifunction I/O Accessory Guide
https://www.ni.com/en/support/documentation/cable-accessory-guide/daq-multifunction-i-o-cable-access...
NI 78xx Models: R Series Cable and Accessory Compatibility
https://www.ni.com/en/support/documentation/cable-accessory-guide/ni-78xx-models--r-series-cable-and...
Insider tip: Use an external search engine such as Google to find NI documentation instead of ni.com. It's much quicker and does a better job finding the correct info!
Megan T.
Technical Support Engineer
(2,291 Views)
