PXI
CompactRIO 9159 to laptop connection
I need a development laptop to be connected to the CompactRIO 9159. Since it is very difficult to find the ExpressCard on modern laptops, I would like to know what is the suggested solution to connect to a CompactRIO chassis.
Message 1 of 9
(2,032 Views)
Hello
The Express Cards is actually for PXI chassis. In your case, you want to connect to cRIO chassis for which you can use a simple Ethernet cable or if it's a new chassis, there should be also type C port
Regards
Message 2 of 9
(1,995 Views)
cRIO 9159 is a MXI-Express chassis and it doesn't have a processor on board. Ethernet and type C ports are not available.
Message 3 of 9
(1,991 Views)
Dear Giuseppe,
I got you. I thought that this is a cRIO controller.
So the only way except the MXI controller and cRIO controller is to have a converter like this
Message 4 of 9
(1,985 Views)
The converter you suggested is from ExpressCard to USB, but it is not what I need.
I think the only way to access the PCIe interface on the laptop is to use the thunderbolt interface, and then use a Thunderbolt to ExpressCard adapter, but I would like to have a confirmation that this would work before buying it (it is not very expensive but it still costs few hundreds of euros).
Message 5 of 9
(1,977 Views)
Hi Giuseppe85,
Do you already have an ExpressCard-8360 and a Thunderbolt port? If so, this is the adapter you'll want:
https://www.sonnettech.com/product/echoexpresscard34thunderbolt.html
You'll also need a Thunderbolt 3 (laptop side) to Thunderbolt 2 (Echo ExpressCard side) cable.
- Robert
Message 6 of 9
(1,975 Views)
Thanks a lot Robert.
I'm in the process of buying all the components you suggested. Did you try already this solution?
Message 7 of 9
(1,972 Views)
I've tried the Echo adapter with the ExpressCard-8360 to a PXI Express chassis, not to the cRIO backplane. This was a 5+ years ago, and I was using a Thunderbolt 2 host. I didn't have any problems, but I don't recall how extensively I tested it.
- Robert
Message 8 of 9
(1,968 Views)
That's exactly the information I needed.
Message 9 of 9
(1,956 Views)
