Jack-
Here's a JPEG of how things show up in MAX. This is the original configuration, and so far, the only one that seems to work. To answer your questions, I had a need due to connector layout to swap cards in almost the inverse order that they were in. And, yes, the same thing happens when I just work with one card at a time. As long as the one card is in the original spot, it works fine. Otherwise, it does not show up at all.
