PXI
Can I connect PXIe-8375 to my laptop using ExpressCard?
Hi, Can please some one let me know whether can I connect PXIe-8375 to my laptop using ExpressCard? if Yes can please let me know the part number of that hardware. I tried to search for the solution in NI web site, but I could not able find.
Thanks & Regards,
Santhosh M
(2,484 Views)
Accepted by topic author Sant2108
As I know, the NI ExpressCard 8360 can connect with only PXI-8360. So If you would like to use PXIe-8375, you should use PCIe-8375 with PC.
I attached related link: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kIGYSA2&l=ko-KR
Catharina
(2,471 Views)
The NI ExpressCard 8360 can connect to the PXI-8360 or PXIe-8360 (or there's a chassis or two that can connect directly to the ExpressCard.  As catarina said, the PXIe-8375 can only connect to the PCIe-8375.
- Robert
(2,453 Views)
Thank you for your response.
I saw this information, just wanted to cross check with other users. Thank you very much for the response.
Thanks & Regards,
Santhosh M
(2,450 Views)
