PXI
Call Library Function with C structure
I have been given a MS C++ DLL that I need to call from LabVIEW. The input (and output) to the DLL are pointers to "C" data structures.
The LabVIEW "Call Library Function" VI allows you to add input parameters and define their type (I.e. Numeric, Array, String, etc.) However, "C data structure" is not one of the options. Is there a way in LabVIEW to call/use a MS C++ DLL that requires a data structure as an input and returns a data structure as the output?
Message 1 of 1
(2,962 Views)
