PXI
Automatic testing system based on PXI
Hi all friends, my master project is BUILD A AUTOMATIC SYSTEM  TO MEASURE MACHINE VIBRATIONS WE USE PXI BUS, i want any help about this topic? thank you
Message Edité par Badis le 02-11-2010 07:43 PM
Message Edité par Badis le 02-11-2010 07:44 PM
(3,264 Views)
Hi Badis,
Welcome to the forums!  I am happy to hear you are using PXI for your project, do you know what cards you are using?  How are you going to control this project do you have one of our integrated controllers or are you possibly usinga MXI connection?  How are you going to program this project?  Are you going to use LabVIEW, C, CVI, or something else?  Can you describe the machine you are measureing from (the signals you expect to see) and what sensors you are using?  We have tons of documents on both vibration measurements and how to set these up!  If you can be a little more specfic as to what exactly you are looking for help with and what you have tried so far we should be able to assist.
Sincerely,
Jason Daming
http://www.ni.com/support
(3,248 Views)
