11-11-2008 12:26 PM
So I have a PXI 6255 in a NI 1033 chassis and I have connected a trigger from my laser running at 1kHz in the APFI0. When I use DAQmx (the latest version) to configure a task, it runs without problem if I do it without a trigger. As soon as I connect a trigger though I get error number 200284. The trigger parameters are rising analog edge with 5V.
I´ve tried modifing the sample number from 2 to 200 to make sure it´s not a timeout issue as well as increasing the default 10s clock to 1000s. I´ve also played with the rep rate a bit but looking at my trigger siganl on an oscilloscope gives me the proper value so I don´t think that is the problem either.
I am also pretty sure that the trigger is being read by my hardware as the signals I get are slightly modulated after I connect the trigger.
I have not configured an external clock.
All help greatly appreciated
Mirabelle
11-11-2008 01:26 PM
11-12-2008 12:39 PM
OK, it works now!
Thanks anyways 🙂
