PXI
Analog Output Voltage non-zero (using a pxi-8336)
Earlier I posted a question about the voltage being too high for the first second of a programmed output.
The actual problem seems to be that the output from the analog out is always some non-zero voltage. There are two analog outputs on the card, the first has an output of 0.98 V and the second has an output of 0.5 V, which is constant all the time.
I have tried turning the chassis off and on, and resetting the device in "Measurement and Automation Explorer".
"Measurement and Automation Explorer" has a window in which you can set the base output voltage, that voltage is set to zero. Even if it were set to a different value that would not explain why one channel should be at 1V and the other at 0.5V.
Thanks for any help.
Mike
(3,316 Views)
Hey Mike,
If you can, please continue to post on your original post. Please reference your original post for further information.
Thank you,
Simran K.
Message Edited by Simran_K on 06-11-2008 01:16 PM
Simran K
(3,303 Views)
