PXI
Accessing a SWTICH and DMM cards in a PXI System remotely
Hi everybody,
I use a PXI system with a NISwitch PXI-2503 and NiDMM PXI-4070. The embedded controller PXI-8176 is running WinXP.
From a client machine I want to access remotely this cards. Via VISA Server it is possible to interact with the Switches using NI's driver NiSwitch. On the ther hand, I did not succeed so far to access remotely the DMM using the driver software NiDMM. I receive always the following error:
"Error -1074135030 occurred at niDMM Initialize.vi
Possible reason(s):
Error: (Hex 0xBFFA000A) Failure loading driver module."
My Software Versions are:
Labview 7.1, VISA 3.1, NI-DAQ 2.10, NiSwitch 2.20, NI-DMM 2.2.1
I have read that there are some incompatibilities between VISA and RDA conc
erning the TCP-IP port, but this problem should be solved in the versions I currently use.
Anybody out there who knows a workaround?
Thanx for any help in advance
Hannes Schmidt, Swiss Federal Institute of Technology, Lausanne
(3,295 Views)
Hannes,
Unfortunately I don't think anybody here knows of a workaround because the application is not one that anybody has recently tested using NI-DMM. The easiest work around to me would be to use LabVIEWs remote front panels to do the acquisition. The only reason why using this might cause a problem is if you need to save data to file on a remote PC. So the only consideration to work with is to save the file on the host PC and then grab the file saved using FTP or something along those lines. That may be a much easier work around than trying to figure out what is going on with the low level DMM driver call. Hope this helps. Good luck with your application.
Best Regards,
Jeremy Ross
NI - Applications Engineer
(3,295 Views)
