PXI and Instrumentation Idea Exchange
About PXI and Instrumentation Idea Exchange
Have an idea for new PXI hardware or software features?
  1. Browse by label or search in the PXI and Instrumentation Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see implemented!
Top Authors
SLSC Chassis with EtherCAT
Hi all,
 Proposition: make an SLSC chassis controlled over EtherCAT. Would be a great addition to a realtime HiL system with a lot of IO to be switched/faulted by providing deterministic switch capabilities. It's not always feasible to buy that many PXI switch cards...
E.g. our DUTs have usually about 100 IO lines (some even over 150), each of which have to be tested for open, short to another one, self-short (in case of differential lines) etc. We usually don't have a requirement to switch very fast, but we'll welcome a possibility to switch in predictable time.
Piotr F.
Hardware Engineer @ ZF
