VeriStand
[Custom Device][XXX Initialization VI.vi] how to use "Custom XML" termal?
Message 1 of 10
(10,014 Views)
What custom device are you using here? Was it something from the Community, or something you, or someone you're working with made? Most community devices have a feedback and support page. Also it would be helpful if you posted a screenshot of the block diagram. We cannot tell from just the front panel what this control is connected to downstream in your program.
Miles G.
Emerson Test & Measurement Group
Senior System Support Engineer
Message 2 of 10
(9,816 Views)
Accepted by topic author hm7
The content of that string is whatever is inside the customxml tag inside the custom device xml
http://zone.ni.com/reference/en-XX/help/372846G-01/veristandmerge/cd_xml_tags/
Stephen B
Message 3 of 10
(9,804 Views)
thank you fou your help.
I have another question about this "customXML"tag. I want to get some information from the 'customXML' terminal in the "custom device initialization VI.vi" . I change the custom device XML file manually, when I load the SDF file, I get an error.
If I use the names that the custom device xcd file contained, there is no error, but I still can't get the information.
Message 4 of 10
(9,132 Views)
I do a test as below. It shows that when the initialization.vi is runnig, the customXML termainal was wrote.
Message 5 of 10
(9,125 Views)
waiting!!!
Message 6 of 10
(8,989 Views)
Latecomer to this discussion, so I apologize if this is stupidly out of context . . .
hm7, I believe that you need to have valid XML tags inside that Custom XML section (not just text).
For example you could put in the following:
<Popup Text>Hello</Popup Text>
I'm fairly certain that what you currently have is not valid per the XML Schema (Custom Device.xsd).  I've used this tool before to validate XML: http://www.freeformatter.com/xml-validator-xsd.html
Chris
Project Engineer
Certified LabVIEW Architect
Certified TestStand Architect
Message 7 of 10
(8,956 Views)
the tag between the last two tags of <CustomXML> should be enter as "<Dummy>" as follows
Message 8 of 10
(8,918 Views)
Can you give me an example for this? I try many times but failed.
Message 9 of 10
(8,885 Views)
you could refer to any xml file of custom device example at C:\Users\Public\Documents\National Instruments\NI VeriStand 2013\Custom Devices as attachment.
if it doesn't work for you ,  I think you had better to rebuild the custom device from the custom template tool step by step.
Message 10 of 10
(8,827 Views)
