06-15-2017 09:38 AM
Hi all,
Does it exist the capability to change the screen sequence into VS *.nivsscreen workspace?
I mean :
In traditional workspace (not in UI *.nivsprj file) I can create different screen sections (e.g. screen1,screen2,...)
I can list the result in window dialog box (see below)
Now I would change the screen sequence in the dialog and swap the position of screen1 and screen2 :
How can I do this ? is there a file to edit I suppose, which?
06-21-2017 02:51 AM
You can change the order.
.nivsscreen file is written in XML format, you can see the following tag.
<Property Name="Screen Order">
<I32Array>
<Elem>0</Elem>
<Elem>7785</Elem>
</I32Array>
</Property>
Change "Elem" order.
06-23-2017 01:03 AM
Thanks!!!!
06-23-2017 02:29 AM
06-23-2017 02:36 AM
It works
