NI VeriStand Add-Ons Discussions
How to get PXI (Pharlap OS) Mac Address using C code ?
Hello everyone,
I would like to use NI Veristand Simulation Model (using extern dll) in RT target (pharlap OS).
I create my C-code using NI VeriStand Model Framework and I'm able to deploy  my dll inside the target.
Problem: I would like to get the Pharlap MAC Address Target inside my C code.
Pharlap ETS uses a Win32 subset API.
Have you some suggestion on what API (or library or command),  RT compliant, can I use for getting PXI (Pharlap) MAC Address ?
I tried netbios using a code like this:
http://tangentsoft.net/wskfaq/examples/getmac-netbios.html
but it use NetAPI32.lib library that isn't compliant for RT Target.
Thank you in advance,
Cosimo
Message 1 of 1
(3,977 Views)
