NI VeriStand Add-Ons Discussions
Embedded Data Logger and RT logger
My customer wants to log data at 10kHz rate with the following conditons:
two models: CarSim Vehicle model at 2kHz rate and simple Simulink actuator model at 10kHz rate.
The hardware is basically two R series FPGA boards, so 16 AIs, 16 AOs, and some DIO channels.
At this point we are not achieving this perforamance with PXIe-8133RT and PXI-8109RT.
Here is our performance result:
CarSim: 1.6kHz
Simple Simulink Model (2nd order auto suspension model we often use for SIT demo): 5kHz
PCL: 5kHz
Embedded Data Logger Custom Device: 2kHz
Can we run PCL at 10kHz rate as well as simple simulink model at 10kHz?
Can we also log about 10 - 20 channels of data at 10kHz rate using Embedded Data Logger, or should we wait for VeriStand 2012 buffered IO feature?
Best,
Michi
(4,234 Views)
Hey Michi,
This community is for NI VeriStand add ons. If you need general NI VeriStand support, it should not be posted here.
Stephen B
(3,399 Views)
