NI TestStand
why "Limits" does not appear in the locals resultlist of the "Numeric Limit Test"
Hi All,
    Why the "Limits" does not appear in the locals resultlist of the "Numeric Limit Test" step type,but the "Units" is appear;I refer the NI KnowledgeBase:http://digital.ni.com/public.nsf/allkb/37632B9C2C1CFCF286256BC20072AC14, But it's can't fix my issue;anybody have experience on this????(I use Teststand 2010 and LV2010);
(5,257 Views)
Looking on the first screenshot you provide, i see a step with the result "Done" as step 0 in ResultList.
A numeric limit step should never get a "Done". So i assume that your step 0 is no numeric limit step, so it does not have limits to evaluate against. I would expect this step to be an action.
Please verify this and explain why you attached a screenshot of typeflags if you don't show whicht step type you are looking at.....
Norbert
Norbert
Expert: Geometry
(5,253 Views)
Yes,ResultList[0] is "Action" step type,But the Result[1]...[10] are "Numeric Limit Test" step type,there are no "Limits" and "Comp" appear,i attched the wrong screenshot  picture,i will attched a new one later;
(5,249 Views)
If "Limits" of step types which include those are not part of the ResultList, i would expect your machine to not "Include Limits In Results". This is a step included in the process model. Do you use a custom process model?
If yes, please check if it calls the AddExtraResult method for "Limits" and "Comparison Type" like the default process models do.
Norbert
Norbert
Expert: Geometry
(5,242 Views)
i use the custom process model seq,and it call the addExtraResult method for "Limit" and "Comp" too,
(5,225 Views)
Your call to AddExtraResult has a precondition configured. Are you sure it evaluates to TRUE during execution?
It is possible it refers to the setting "Include Limits" in the Report Configuration dialog.
Norbert
Norbert
Expert: Geometry
(5,219 Views)
I checked precondition of AddExtraResult and set it TRUE; The Report Configuration dialog also include Limits;
Last,I copy all the TestStand folder from another computer,So I don't find the root casue;But still Thank you for you help;
(5,199 Views)
