NI TestStand
what is different between functional global variable and file global varial
hi,
     wahat is different between function global variable and file global variable in NI test stand(2014) .
(6,009 Views)
There are no "function global variables" in TestStand. What is this?
Assumption: You talk about "STATION Global Variables".
Station Global: Stored in StationGlobals.ini and availble for all sequence files on the specific test system (installation)
File Global: Accessible in all sequences inside the sequence file which defines the variable, but not accessible in other sequence files.
Norbert
Expert: Geometry
(5,998 Views)
yes this station global only.
but still now i am not undershoot what is different because both are using all sequence.
(5,969 Views)
File Globals are used within a single Sequence File. You are right that they can be used by all sequences within that file, but no other sequence file can access that data.
A Station Global stores information outside of the sequence file. It is usually used for storage of test station information, or user information; the kinds of things that don't change between sequences. They also don't return to a default value after sequences execute, they maintain their value after execution.
Nic
Nico
Systems Engineer
Certified TestStand Architect Certified LabVIEW Architect
(5,966 Views)
ok than what is different local variable file global variable because local variable also using single sequence only .
(5,949 Views)
Accepted by topic author GokulGKM
Attached is the TestStandSystemandArchitectureOverviewCard.pdf.  Look at the section titled: Sequence File Structure.  It shows the scope of the different variables.  Here is a brief description of all the different types of variables you can have in TestStand:
StationGlobals = Accessible by anything on the station.
Sequence File Globals = Accessible by only members of the sequence file within which the Sequence File Global is defined
Locals = Accessible by only members of the sequence within which they are defined
Parameters = Accessible by only members of the sequence within which they are defined.  Used to pass data from the sequence to the caller and vice-versa
Step Properties = Accessible by only the step within which it is defined
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(5,946 Views)
Also- please note that there is a huge difference between sequence file and sequence.  One is a file and one is an object within the file.
jigg
CTA, CLA
testeract.com
(5,945 Views)
