NI TestStand
use ni usb 600x in Testand
Hello everyone,
I am currently trying to use I/O of an NI USB 6001 under teststand but I cannot find what .dll to call to handle the setting from the I/O.
Does anyone know the proper DLL to use ?
I already setup NI DAQmx and can pilot the 6001 on the side. And FYI I won't use Labview so I need to drive it directly.
Regards
(1,396 Views)
Using NI-DAQmx in Text Based Programming Environments
You can use C, C# or Python. Most likely you would need to create a wrapper DLL based on the shipping examples. I don't think it is a good idea to call the API directly in TestStand.
https://tmesystems.net/
(1,371 Views)
NI website reference this page
Note, this is not a NI product, but a toolkit developped by the french company Mesulog (I used ot work here, I've worked a bit on this product).
The current version (1.0.3) can be dowloaded from here, and the online help is available on this page.
Hope this helps,
(1,348 Views)
excellent, merci.
I'll take a look for the details.
(1,342 Views)
