NI TestStand
timeout
How do you handle a timeout in Teststand with a LV8.x adapter?  Or any error generated by the OS??  I'm using one of the shipped vis that writes to 1 serial port (com 3) and reads from the other (com4).  Its a simple wrap test.  If I don't anything connected to one of the ports I get an error.  This is something I'm checking for.  I want TS to handle this not the operator.
Clint
(3,045 Views)
In your code module (LabVIEW in this case) you will need to pass the error information back out as a step argument.  You can then use post-expressions of the step to evaluate it and then based on that, handle it appropriately.
Kristen
(3,020 Views)
