NI TestStand
teststand Deployment error
I am getting the error below when attempting to build a TestStand deployment.
teststand version:2017 64-bit
labview version 2018 32-bit
error:
source  code:
(1,622 Views)
Accepted by topic author chelizhou
The error clearly states "The bitness of LabVIEW does not match the bitness of the deployment utility." and you do confirm that you're using TS 2017 64-bit with LV 2018 32-bit, why not just switch one of these to match the other? simple!
Santhosh
Soliton Technologies
(1,602 Views)
