NI TestStand
testing boolean in multiple numeric limit test
Hi ,
My VI is giving out 3 booleans and 2 numeric values which are needed to be  tested. Can we use "multiple numeric limit test" and if so how do we do that?
Regards
Prav
(4,129 Views)
I would use the Boolean to (0,1) function and have all of the results numeric.
(4,124 Views)
Str(Locals.DATA_valid)=="True"?1:0
(983 Views)
If DATA_valid is a boolean, then the expression can simply be:
Locals.DATA_valid == True ? 1 : 0
(933 Views)
Locals.DATA_valid ? 1 : 0
(903 Views)
That's what I originally intended but somehow got mentally stuck on the True from the original post.
(889 Views)
