NI TestStand
test code module labview
hi i'm begginer in teststand ,so i have to test a code module in labview ,this vi every second give a data (the vi is in while loop) ,in the teststand when i excute doesn't stop, so i should stop the test from labview ,so what should i do .(sorry for my poor english).
some screenshots:
(2,551 Views)
Your screenshots, except the first one, sadly do not help in investigating the issue.
However, my understanding is that the VI includes a loop and does not return to TS by itself. If that understanding is correct, you have to change that. Another thing you want to change is that Step.Result.Numeric is the parameter where you pass data FROM the module into. You are using that variable as input to the VI which is not correct.
Norbert
Expert: Geometry
(2,489 Views)
