NI TestStand
step post action works only in 'Test UUts' mode
Hi Norbert,
This is not how it works on my machine....and I've just checked it on another machine and it behaves just the same.
I attached the seq file I have been experimenting with.  If you select both steps and run them as 'Run Selected Steps' , it will fail the first one and continue to the next.
If, however you will change the destination jump to <End Group>, it will work just fine.
Rafi
Message 11 of 13
(1,050 Views)
Rafi,
on my machine, everything works as expected. If selecting all four steps of your MainSequence and selecting "Run Selected Steps using Single  Pass", the first subsequence call is executed. This will lead to a SequenceFailed == true.
Therefore, the postaction is executed and the next subsequence call is not executed. Attached you can find the reportfile from this execution....
hope this helps,
Norbert
PS: Since the forum does not accept attachments in xml-format, i just renamed it to jpg. This file is no image file but an XML report file! So please change the ending to .xml in order to access it.
Norbert
Expert: Geometry
Message 12 of 13
(1,047 Views)
Accepted by topic author Rafi2003
Hi Norbert,
You are right....I did not include the "destination jump" step in my steps to run.  I now noticed that you have written that in a previous mail.  Sorry, I misunderstood you.
It works fine now
Rafi
Message 13 of 13
(1,042 Views)
