NI TestStand
step pane custom layout when Test UUTs (F5) is pressed
I have noticed, that when executing a sequence in test-stand the steps pane lay out is different, where some tabs in parallel model are all in one row, while other workstations have them in multiple columns/rows.  I am pretty sure there's got to be a way to control this, but I just don't know how to.  See the pictures attached, if what I am saying isn't clear.
Tried messing with UI configuration under the Sequence Editor Options, but it doesn't seem to do it for me.
Thanks for the Help!
(4,885 Views)
Accepted by topic author rsmrostov
go to: Configure | Model Options | remove the tick "Tile execution windows"
that should prevent the executions of appearing in separate tiles 🙂
Best Regards
Mathis
(4,878 Views)
Thank you so much, I will try that!
(4,816 Views)
