NI TestStand
setting parameter array values in teststand
I am trying to change a parameter array value in the pre-expression of a test step in a sequence file. I want to pass the array to a vi to set digital lines and relays. However, I get an error every time. Is this an operation that is supported?
Here is my syntax: Parameters.DIO(0)=true
Here is the error returned:
-17320; Unknown function or sequence name.
The pre-expression for the step 'Action' could not be evaluated.
Unknown function or sequence name '.'.
(3,351 Views)
I think you need to use square brackets '[', not round ones, to index arrays.
Parameters.DIO[0]=true
Sacha Emery
National Insturments (UK).
// it takes almost no time to rate an answer Smiley Wink
(3,351 Views)
Thank you Thank you. Sometimes it's the smallest things.
(3,351 Views)
