NI TestStand
sequencefile name
I'am a first time user of Teststand with a problem.
In CVI I want to read the name of the sequencefile im in at that moment. I have tried this
ERRORINFO errorInfo;
static char *CommentString;
static CAObjHandle objhFile, File;
TS_SeqContextGetProperty (testData->seqContextCVI, &errorInfo,TS_SeqContextSequenceFile, CAVT_OBJHANDLE,&File);
TS_SeqFileAsPropertyObject (File, NULL, &objhFile);
TS_SequenceGetProperty (objhFile, &errorInfo, TS_SequenceName,CAVT_CSTRING, &CommentString);
But this doesn't work.
Also, I want the name of the sequence file one level higher (when I call a seq. file out of a seq file).
(4,194 Views)
SoftToon,
In your code above, you are actually referencing the sequence instead of the sequence file in your last API call. I have included some code that should get you the correct results.
Hope this helps!
static char *seqFileNameStr;
static TSObj_Property seqFileName;
static CAObjHandle seqFilePropObj;
static TSObj_SeqFile seqFile;
TS_SeqContextGetProperty (testData->seqContextCVI, NULL,TS_SeqContextSequenceFile, CAVT_OBJHANDLE, &seqFile);
TS_SeqFileAsPropertyObjectFile (seqFile, NULL, &seqFilePropObj);
TS_PropertyObjectFileGetProperty (seqFilePropObj, NULL,
TS_PropertyObjectFilePath, CAVT_CSTRING, &seqFileNameStr);
MessagePopup ("Sequence File Name", seqFileNameStr);
Shannon Rariden
(4,194 Views)
Hi Shannon,
this is interesting.
but i could not get the same sequencefile name programatically in my sequence.
how can i get this?
I have used NameOf(Runstate.SequenceFile). It returns Empty string.
(3,825 Views)
NameOf(RunState.SequenceFile) doesn't work because there isn't a Name property for SequenceFile. Checkout the TestStand Help for SequenceFile to find it's valid Properties.
Follow the example given by Shannon.
Regards
Ray Farmer
Regards
Ray Farmer
(3,818 Views)
Hi Ray,
nice to see your quick reply.
Yes. i have seen the properties and found that "name is not among them"
But i just blindly followed the below link
http://digital.ni.com/public.nsf/allkb/AC5008A6FC55616F86256BBC005B61D8
where a solution says it is possible to get the Sequence file Name.
Still i can figureout the expression to get this. Can u help me with that?
(3,814 Views)
Locals.name = RunState.SequenceFile.AsPropertyObjectFile.DisplayName
This should return the filename part of SequenceFile.Path which is the full path including filename of the current sequence file.
Regards
Ray Farmer
Regards
Ray Farmer
(3,795 Views)
