NI TestStand
sequence file documentation report doesn't show the step parameters
The Step parameters is missing in this report. Is there a way to add this just as you have included the Sequence parameters. Thanks.
Sequence: MainSequence
Type:  Normal
Disable Results for All Steps: False
Goto Cleanup on failure:  Use Station Option
Number of Setup steps:  2
Number of Main steps:  10
Number of Cleanup steps:  2
Parameters:
PartNumber String (by reference)
Step: Setup Instruction
StepType, Adapter:  Message Popup, <None>
Description: NameOf(Step)
Module Load and Unload Options: Preload when execution begins, Unload when sequence file is closed
Record Results:  Disabled
Flow Properties:  Post Action:
   if ()
      Goto <Cleanup>
Result Recording: Disabled
(3,251 Views)
Accepted by topic author jjapuy
I agree that this is frustrating.  I had the same issue recently.
You should post it in the idea forums: http://forums.ni.com/t5/NI-TestStand-Idea-Exchange/idb-p/teststandideas
Or you can edit the sequence that generates these and include the parameters.  The source for this is in: <TestStand>\Components\Tools\DocGen
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,233 Views)
