NI TestStand
search and delete step from result list
What i want to do is basically what it is stated, search a result list for a particular step and delete it.
 On the example i have a case structure each case will call a sequence. so before executing the sequence i want to find if that step was chosen before in order to delete the previous result and keep the new one.
i know that on the result list array, the name of the step is stored here Locals.ResultList[x].TS.StepName
so how i wanted to solve the problem is by doing  looping through  Locals.ResultList[x].TS.StepName until the step name is equal to TheRunState.NextStep.Name. Then if that is true do Locals.ResultList.DeleteElements(Locals.postodelete,1,0)
i have tried this but no luck, i tried with a looping statement and didnt work. some race conditions are inolved thats why i have some locals created there.
any ideas?
CLAD, CTD
(5,207 Views)
I found a community example that deletes from the result list: https://decibel.ni.com/content/docs/DOC-15520
Is your issue coming from the actual deletion or from finding the right step to delete?
(5,138 Views)
Hi buton,
1.) Static: Settings pane Properties->RunOptions->Result Recording Option->Disabled
2.) Dynamically : Last step Result: Statement: SetNumElements(Locals.ResultList,GetNumElements(Locals.ResultList)-1
Just see the Example
Hope that helps
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(5,132 Views)
