NI TestStand
remove variable dynamically
Is it possible to Remove a variable in runstate?
For example "Locals.ResultList[0].TS.SequenceCall"
To remove a resultfree sequence from report
In fact I have a sequence call that calls a sequence, I disabled "record results" of all steps in that sequence. But I need to show a result for the "Sequence Call" step itself which is already handled with parameters. TestStand stores an empty "ResultList" just for the subsequence, and it shows that a sequencecall occurred. Its not very fency and I would prefer to show only the result of the "sequencecall" step
Hope it's kinda clear 🐵
Jimmy
(5,359 Views)
The ResultList is an array therefore you can use the PropertyObject.DeleteElements method to delete that result. Check out the help in the Programmers Reference.
Hope this helps you.
Regards
Ray Farmer
Regards
Ray Farmer
(5,349 Views)
Hi Ray,
unfortunately I tried this but the fact is the record result array is already empty. So that's why I was looking for completetly remove the mentionned container variable  "Locals.ResultList[0].TS.SequenceCall"
Is there a method like Locals.Variable.Remove ?
Jimmy
(5,337 Views)
Hello Jimmy,
You can use the DeleteSubProperty method to do this.
With warm regards,
David D.
(5,331 Views)
I think I just don't understand how to spell it correctly.
I created Locals.Local
in a statement I put PropertyObject.DeleteSubProperty("Locals.Local",0) and it returns Error accessing PropertyObject Variable...
I tried Locals.Local.DeleteSubProperty("Locals.Local",0) and it returned Error accessing "Locals.Local"...
Jimmy
(5,327 Views)
Hello Jimmy,
Locals.DeleteSubProperty("Local", 0) is what you are looking for. Check the help for DeleteSubProperty for a link to more information on lookup strings.
With warm regards,
David D.
(5,323 Views)
Accepted by topic author JICH
It makes sens,
thank you very much guys
Jimmy
(5,320 Views)
