NI TestStand
remove local variables
I have created a custom edit step (LabVIEW VI) in which the user can create a Local, StationGlobal or FileGlobal variable to store some data in.  When the user hits the "add" button an event is triggered and the variable is created.  I want the user to be able to hit the "remove" button and cause an event to be triggered that removes the variable.  Is this possible, or do I need to specify that the user removes the variable manually?  The front panel and add portion of the block diagram is attached.
(3,347 Views)
Try to use DeleteSubProperty
Check out example
Hope this helps
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,340 Views)
Thank you, Juergen!  I added to my VI and it works like a charm.
(3,323 Views)
