NI TestStand
"Diff Sequence File With" doesn't look into sub-sequences.
Hello guys.
I have these 2 sequences in Teststand 2.0 that I'm trying to compare, but when I use the command "Edit" - "Diff Sequence File With" it only looks in the upper level properties (MainSequence, FileGlobals, etc.) but it doesn't check for the contents inside the sub-sequences, which is where I have most of my measurements and tests.
Hope you can help. Thanks.
(3,289 Views)
If you expand the 'Sequences' node, you should see the list of all the sequences from your file.  Then expand one of the Sequences and it should list the Context variables for those Sequences.  This is where you should see a comparison of the Locals set.  As a test, try comparing the Sequential (SequentialModel.seq) and Batch (BatchModel.seq) process models.  You can find them in the <TestStand>\Components\NI\Models\TestStandModels directory.  Perhaps you could post the two sequences you are trying to compare if you are still running into problems.
Tyler T.
(3,274 Views)
Could you post a jpg highlighting your problem.
Regards
Ray Farmer
Regards
Ray Farmer
(3,271 Views)
