03-14-2006 07:35 AM
03-14-2006 09:07 AM - edited 03-14-2006 09:07 AM
Message Edited by SercoSteve on 03-14-2006 09:16 AM
07-02-2013 11:55 AM
Hi
I inserted in this conversion because I also have a problem when I want to create a local variable with Teststand 2010.
To create programmatically a new local variable, I use the NI teststand API ( PropertyObject.NewSubProperty) The problem is the local variable is available during runtime but I don't see the variable in the local variable pane after the end of the runtime.
What is the best method to solve the problem?
Xavier
